Reverse Polarity (after power stops)
Postby pebe » Fri Apr 29, 2011 1:52 pm
It depends on your timer. If it uses a relay to drive the load, then no problem. You will need a diode only if there is a warning about using it with an inductive load.
But if you want to be sure, connect a 1N4001 across the coil. Connect the diode with its cathode to positive side of the relay output.
DPCO is Double Pole Change Over
DPDT is .DP....Double Throw
DP2W is DP....Two Way
They are all the same.
Best regards to a Yankish and his dad from a 'sassenach' in Scotland :lol:
Previous
Schneider Electric PAS600L ECOSTRUXURE PANEL SERVER + Sensors Complete System.
$900.00
Schneider Electric PAS600L ECOSTRUXURE PANEL SERVER  + Sensors Complete System. pictureSCHNEIDER ELECTRIC PAS600PWD PoE ECOSTRUXURE PANEL SERVER GATEWAY
$400.00
SCHNEIDER ELECTRIC PAS600PWD PoE ECOSTRUXURE PANEL SERVER GATEWAY pictureSIM Bank 32 SIM Card Slots Ethernet SIM Server for GoIP
$600.00
SIM Bank 32 SIM Card Slots Ethernet SIM Server for GoIP pictureBitmain crypto mining server Switching Power Supply (amazing specs for your PC)
$35.00
Bitmain crypto mining server Switching Power Supply (amazing specs for your PC) picture
