Voltage Limiter help!
Postby DJ Higgumz » Sat Mar 10, 2012 3:15 am
building a sub box for a friend, and i want to limit output from the amp to 19 volts. don't get on me about miscalculation of volts, this sub is very efficient, at like 110db per 1 watt, that is the correct voltage :) . anyways what I want to achieve is to have something to limit the voltage once it gets to that point. even if it is a led that turns on at 19 volts that would work. simplicity and affordability are key! new user so be nice :D
DJ Higgumz
$17.92
$40.50
$225.00
$11.06
