Hi I'm new to electronics and need some help
Postby Dano3256 » Sat May 19, 2012 4:36 am
I want to make a small 9 volt motor run for 2 sec at a time and I want to have a choice of 15 sec, 30 sec, 1 min, and 2 min delays in between runs. Any help would be great thanks Danny
Dano3256
Re: Hi I'm new to electronics and need some help
Postby electric_guide » Sun May 27, 2012 1:18 pm
well, the timing circuit is easy.
you can use a 555 component and connect the output to a NPN transistor or FET to drive the motor (it depends on the motor type).
google for "555 timer"
About the motor: what motor is it? brush ? step motor? servo?
(Edit: Advertising has been removed - Moderator)
electric_guide
Postby pebe » Tue May 29, 2012 8:41 am
[quote="Dano3256"]I want to make a small 9 volt motor run for 2 sec at a time and I want to have a choice of 15 sec, 30 sec, 1 min, and 2 min delays in between runs. Any help would be great thanks Danny[/quote]
You could use a 4060 binary counter if you can accept an 'On' time of 1.875secs instead of 2secs. Alternatively, with a 2sec 'On' time, you would have times of 16secs, 32secs, 64secs or 128secs.
Let me know if you need a circuit.
$1.80
$32.62
Rectifier Diode 10A 1000V Electronic Silicon Diodes 200pcs for 10A10 picture20 Values Diode Assortment Kit Rectifier Schottky Fast Recovery Diodes Set
$17.99
20 Values Diode Assortment Kit Rectifier Schottky Fast Recovery Diodes Set picture4-Channel MOSFET Driver Board 5-24V DC Switch Module Arduino ESP32 | KI Maker
$19.95
4-Channel MOSFET Driver Board 5-24V DC Switch Module Arduino ESP32 | KI Maker picture
