X axis problem
X axis problem
Postby joethepro » Mon Mar 11, 2013 7:48 pm
I'm looking for the simplest way to build a gantry that travels back and forth on the X axis only without it being hooked up to a computer. It will be belt driven and controlled by an 18v dc drill motor.
I was thinking about using an "on-off-on" switch at each end of the gantry slide to reverse the direction of the gantry, but I think the motor won't last long if I do it that way. I need something to slow the motor at each end before it reverses direction.
I've thought about Hall sensor's, 555 timers, limit switches etc., but they seem complicated being that I don't know much about hooking them up. Just want something simple.
Any idea's?
joethepro
Re: X axis problem
Postby JoshMac » Mon Apr 15, 2013 6:17 am
is it a fixed length linear movement, or does it need to be adjustable?
one idea is to change the way you are doing it a little, using some linear bearings (pretty cheap if you look around) on a axis.
I have attached a google sketchup drawing of what im talking about.
contact me with your email if you want me to send the sketup file.
I have made a couple of things using this method in the past for friends.
Good luck
JoshMac
Tektronix TR503 Tracking Generator and TM503 Power Mainframe
Tektronix TR503 Tracking Generator and TM503 Power Mainframe pictureNational Instruments NI PXIe-1073 Chassis / 5-Slot PXIe Mainframe w/ MXI-Express
$435.00
NI National Instruments 778643-01 Front Rackmount Kit for PXI - 8 Slot Mainframe pictureNational Instruments NI PXI-1042Q Chassis / 8-Slot 3U PXI Mainframe. TESTED
$225.00
National Instruments NI PXI-1042Q Chassis / 8-Slot 3U PXI Mainframe. TESTED picture
