Need 555 flyback circuit w/ adjustable frequency and pulse
Postby krheath » Fri Jul 19, 2013 8:04 pm
I need a 555 timer circuit with separate, variable frequency and variable pulse to drive a flyback transformer from a crt monitor. Its purpose is to pulse a special coil with high voltage and high frequency.
krheath
Re: Need 555 flyback circuit w/ adjustable frequency and pul
Postby pebe » Sat Jul 20, 2013 2:37 pm
I Googled for "555 flyback circuit w/ adjustable frequency and pulse" and got 487,000 hits.
Surely at least one of them must be just what you want?
$27.04
$13.63
DC 12V 0.3A Solenoid Electromagnet Push Pull Type 5N 10mm Open Frame JF-0530B pictureSDC Electromagnetic 650 LB Lock 1581SNDV Exit Check Delayed Egress System
$85.00
SDC Electromagnetic 650 LB Lock 1581SNDV Exit Check Delayed Egress System picture12V 24V DC 2.5-150KG Electric Lifting Magnet Electromagnet Solenoid Holding Coil
$38.44
12V 24V DC 2.5-150KG Electric Lifting Magnet Electromagnet Solenoid Holding Coil picture
