Need 555 flyback circuit w/ adjustable frequency and pulse
Postby krheath » Fri Jul 19, 2013 8:04 pm
I need a 555 timer circuit with separate, variable frequency and variable pulse to drive a flyback transformer from a crt monitor. Its purpose is to pulse a special coil with high voltage and high frequency.
krheath
Re: Need 555 flyback circuit w/ adjustable frequency and pul
Postby pebe » Sat Jul 20, 2013 2:37 pm
I Googled for "555 flyback circuit w/ adjustable frequency and pulse" and got 487,000 hits.
Surely at least one of them must be just what you want?
10 pcs 10K ohm Linear Taper Rotary Potentiometer Panel pot B10K 20mm
$10.30
10 pcs 10K ohm Linear Taper Rotary Potentiometer Panel pot B10K 20mm picture5 Set linear Potentiometer Kit 15mm 3Pin B1K 2K 5K 10K 20K 50K 100K 250K 500K 1M
$6.47
5 Set linear Potentiometer Kit 15mm 3Pin B1K 2K 5K 10K 20K 50K 100K 250K 500K 1M pictureClarostat RA20LASD103A 10K OHM Wirewound 10000 Ohm Potentiometer Industrial POT
$16.90
Clarostat RA20LASD103A 10K OHM Wirewound 10000 Ohm Potentiometer Industrial POT pictureCavitron power potentiometer for Gen 131, 132, 136, 137
$125.00
Cavitron power potentiometer for Gen 131, 132, 136, 137 picture
