Calculating Capacitance
Postby bkmaness » Tue Feb 18, 2014 2:21 pm
On a schematic, would caps in series always be directly in front and behind of each other?
bkmaness
Re: Calculating Capacitance
Postby pebe » Tue Feb 18, 2014 3:20 pm
It depends on what you mean by 'schematic'. If it is a 'schematic layout', ie. a component layout and wiring diagram, then they would be shown as two capacitors - and they could be placed anywhere on the board. But if you mean a circuit diagram - ie. a 'circuit', Then they would almost certainly be shown as one component of the equivalent value, with a note on the circuit stating that the component was made from two capacitors.
$53.99
Adjustable DC 0-30V/60/120V 0-3/5/10A Lab Power Supply Variable Bench Switching pictureEMERSON SOLA SDP 5-5-100T POWER SUPPLY
$90.00
EMERSON SOLA SDP 5-5-100T POWER SUPPLY pictureAcclaim Lighting AL-POWER 4 HP 200W DMX LED Driver Power Supply Controller
$399.99
Acclaim Lighting AL-POWER 4 HP 200W DMX LED Driver Power Supply Controller picturePower Supply with Bracket 4500-PS
$60.00
Power Supply with Bracket 4500-PS picture
