Calculating Capacitance
Postby bkmaness » Tue Feb 18, 2014 2:21 pm
On a schematic, would caps in series always be directly in front and behind of each other?
bkmaness
Re: Calculating Capacitance
Postby pebe » Tue Feb 18, 2014 3:20 pm
It depends on what you mean by 'schematic'. If it is a 'schematic layout', ie. a component layout and wiring diagram, then they would be shown as two capacitors - and they could be placed anywhere on the board. But if you mean a circuit diagram - ie. a 'circuit', Then they would almost certainly be shown as one component of the equivalent value, with a note on the circuit stating that the component was made from two capacitors.
$19.73
$550.00
$169.99
$499.99
