Need help with Diode ID
Postby tom_ » Fri Aug 01, 2014 12:43 pm
I have two diodes in front of me but being absolutely new to electronics I have no idea which is what.
One is a 1N4742 Zener Diode, the other is a 1N4148 diode.
I have no idea which one is the Zener as they look similar. The only difference is the size. One is about half the size of the other.
tom_
Re: Need help with Diode ID
Postby pebe » Fri Aug 01, 2014 6:44 pm
The datasheet for the 1N4148 gives its dimensions as: Length = 3.9mm, Diameter = 1.9mm.
Hope that helps.
Postby yy482 » Sun Aug 17, 2014 1:35 pm
you can search the data sheets from datasheetcatalog.com for the detail
yy482
$13.49
Long-Lasting 4oz Dielectric Grease for Electrical Connectors - USA Made Quality pictureSalisbury 21405WT16 Dielectric Overboot 20 KV Size 16 17 Inch Tall, Deep Heel
$130.00
Salisbury 21405WT16 Dielectric Overboot 20 KV Size 16 17 Inch Tall, Deep Heel pictureLineman Servus Super Dielectric Overshoes Mens Size 8 Brand New Read Lot L
$54.95
Lineman Servus Super Dielectric Overshoes Mens Size 8 Brand New Read  Lot L pictureRFS Manual Grounding Jacket Striping TOOL RFS-916423 RFS 916423 JSTRIP-114
$249.99
RFS Manual Grounding Jacket Striping TOOL RFS-916423 RFS 916423 JSTRIP-114 picture
