Need help with Diode ID
Postby tom_ » Fri Aug 01, 2014 12:43 pm
I have two diodes in front of me but being absolutely new to electronics I have no idea which is what.
One is a 1N4742 Zener Diode, the other is a 1N4148 diode.
I have no idea which one is the Zener as they look similar. The only difference is the size. One is about half the size of the other.
tom_
Re: Need help with Diode ID
Postby pebe » Fri Aug 01, 2014 6:44 pm
The datasheet for the 1N4148 gives its dimensions as: Length = 3.9mm, Diameter = 1.9mm.
Hope that helps.
Postby yy482 » Sun Aug 17, 2014 1:35 pm
you can search the data sheets from datasheetcatalog.com for the detail
yy482
$37.00
Raspberry Pi Compute Module 4 CM4 2GB RAM + Carrier Board pictureFor Dodge Ram 1500 09-18 5.7L Performance Long Tube Stainless Headers NEW
$236.59
For Dodge Ram 1500 09-18 5.7L Performance Long Tube Stainless Headers NEW pictureIntel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit
Intel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit pictureRevolution Pi by Kunbus RevPi Connect 5 | 8GB RAM | 32 GB eMMC
$449.95
Revolution Pi by Kunbus RevPi Connect 5 | 8GB RAM | 32 GB eMMC picture
