Dc electronic viarible pulse (controlled)
Postby Deauled » Fri Aug 21, 2015 1:10 pm
I am trying to build an electronic device, capable of running a 12volt dc selonoid valve at viarible speed, by user input. I would like to know if this is even possible. Any advice would be greatly appreciated.Thanks
Deauled
Re: Dc electronic viarible pulse (controlled)
Postby KMoffett » Fri Aug 21, 2015 7:01 pm
Yes, it can be done. What is the range of speeds that you want to pulse the solenoid valve? Is the solenoid valve capable of moving at you maximum speed?
And more importantly, what are you trying to do with the pulsing solenoid valve?
Often it's easier for us to help solve your problem, than help solve your solution. ;)
$1.80
10pcs  1N4007 Rectifier Diode 1A 1000V - US Seller  pictureAVR Automatic Voltage Regulator For 3Kw-8Kw Generator Rectifier Half Moon Style
$18.99
AVR Automatic Voltage Regulator For 3Kw-8Kw Generator Rectifier Half Moon Style pictureRectifier Diode 10A 1000V Electronic Silicon Diodes 200pcs for 10A10
$32.62
Rectifier Diode 10A 1000V Electronic Silicon Diodes 200pcs for 10A10 picture5Pcs 1000V 50A Metal Case Single Phase Diode Bridge Rectifier KBPC5010 5X
$9.89
5Pcs 1000V 50A Metal Case Single Phase Diode Bridge Rectifier KBPC5010 5X picture
