Dc electronic viarible pulse (controlled)
Postby Deauled » Fri Aug 21, 2015 1:10 pm
I am trying to build an electronic device, capable of running a 12volt dc selonoid valve at viarible speed, by user input. I would like to know if this is even possible. Any advice would be greatly appreciated.Thanks
Deauled
Re: Dc electronic viarible pulse (controlled)
Postby KMoffett » Fri Aug 21, 2015 7:01 pm
Yes, it can be done. What is the range of speeds that you want to pulse the solenoid valve? Is the solenoid valve capable of moving at you maximum speed?
And more importantly, what are you trying to do with the pulsing solenoid valve?
Often it's easier for us to help solve your problem, than help solve your solution. ;)
Hewlett Packard Model HP460BR Fast Pulse Amplifier with Input / Output Adapters
$234.95
Hewlett Packard Model HP460BR Fast Pulse Amplifier with Input / Output Adapters pictureSKAR AUDIO USED SK-M4004D 400 WATT 4-CHANNEL CLASS D MINI CAR AMPLIFIER
$137.49
SKAR AUDIO USED SK-M4004D 400 WATT 4-CHANNEL CLASS D MINI CAR AMPLIFIER pictureAvon VPU Audio Amplifier 71009/2 for Avon FM50 / C50 Respirator Gas Masks
$110.00
Avon VPU Audio Amplifier 71009/2 for Avon FM50 / C50 Respirator Gas Masks picture# BRAND NEW - PASCO Scientific PI-8127 Digital Function Generator / Amplifier
$649.00
