Help on alarm project
Postby JHB1955 » Thu Nov 26, 2015 3:36 am
I have a wireless door bell that puts out a 3 sec, 5 volt pulse and I need it to open a normally closed loop on my 2gig alarm panel. Can this be done using a npn transistor and if so can you recommend the right one to use
JHB1955
Re: Help on alarm project
Postby KMoffett » Sat Nov 28, 2015 3:59 pm
Not sure how much current your doorbell will supply, but for isolation I would look at a 5V normally-closed reed relay.
Postby PradeepKumar » Tue Sep 20, 2016 5:29 am
While you can usually use voltage regulators, it sounds like your wiring may be askew, or possibly something got in and is shorting on the pcb. There isn't really much reason the bell should burn out. All you're doing in drawing power *from* it for the relay. In any case, you may want to have a look at optical isolators. Essentially an led, ldr, and (sometimes) transistor in an IC. They ensure complete electrical separation of the two circuits. You can buy them anywhere, or if you like, salvage them from lots of things (check out transformers, computer PSU's and the like)
PradeepKumar
Postby Relayer » Tue Sep 20, 2016 9:15 am
[quote]it sounds like your wiring may be askew, or possibly something got in and is shorting on the pcb.[/quote]
Where in the original posters post does he mention he has a fault?
Either you didn't read his post properly or you're just throwing in bullshit to make yourself look intelligent.
Seems you failed on both counts.
Instead of helping out what-so-ever, you make it all complicated with all your rhetoric drivel...
Relayer
Relayer
$16.98
$118.84
5000A Phase Control Capsule Thyristor Convex Type SCR Silicon Controlled Ballast pictureSC36205A02 NEW OLD STOCK
SC36205A02     NEW OLD STOCK picture
