US AC Adapter to AU AC Adapter
Postby lynzoid » Sun Nov 29, 2015 2:22 am
Input: AC 120V 60Hz 54mA
Output: AC 12v 250mA Max 3W
My dad says if I get a US to AU plug converter it will just blow the device up and says I need
to buy an identical cord for output that's AU. If so what would I get ?
lynzoid
Re: US AC Adapter to AU AC Adapter
Postby Relayer » Sun Nov 29, 2015 10:18 pm
[b]Hello lynzoid,
I'm assuming you're living in a 240V AC country. if so, then your dad is correct. It will blow the device up.
You're going to need a step-down transformer, something similar to the link below:
[url=http://www.tortech.com.au/step-down-transformer-australia/usa-step-down-transformer/100w-economy-step-down-transformer-240v-to-110v-converter]Step-Down Transformer[/url]
It might be best to shop around for better prices, though 45 bucks Aussie dollars isn't too bad.
I hope the above helps. :)
Relayer[/b]
Relayer
Postby pebe » Mon Nov 30, 2015 4:23 pm
The specified input of '125VAC' shows that it uses a mains transformer and as Relayer said it will blow up on a 240V supply.
A better bet would be a switch mode power supply (SMPS). These normally have an input voltage range that spans both of those voltages. Commonly known as 'wall warts' they are cheap and efficient, and there are hundreds on ebay.
🌟Vintage KISTLER’s Donuts out of Akron Ohio. 🍩 tray with faux pastry display
🌟Vintage KISTLER’s Donuts out of Akron Ohio. 🍩 tray with faux pastry display pictureVintage Central Dualux Solderer 4447 Soldering Station Iron Watch Demagnetizer
$162.41
Vintage Central Dualux Solderer 4447 Soldering Station Iron Watch Demagnetizer picture300+ Vintage National CMOS Semiconductor Lot - See Description
$75.00
300+ Vintage National  CMOS Semiconductor Lot - See Description pictureVintage LAM Systems Desktop PC Intel Pentium Floppy CD DVD Retro Computer READ
$180.00
Vintage LAM Systems Desktop PC Intel Pentium Floppy CD DVD Retro Computer READ picture
