Cut -off frequency
Cut -off frequency
Postby didi10 » Tue Dec 04, 2012 4:20 pm
1. The equation to find the cut-off frequency for a circuit with two multiple poles (at the same frequency the two poles).
2. The cut-off frequency for a circuit with two closed poles Wp1 and Wp2 and two closed zeros Wz1 and Wz2.
didi10
Re: Cut -off frequency
Postby sachinelectrostar » Tue Oct 01, 2013 10:21 am
A cutoff frequency, corner frequency, or break frequency is a boundary in a system's frequency response at which energy flowing through the system begins to be reduced (attenuated or reflected) rather than passing through.
sachinelectrostar
Postby PradeepKumar » Fri Jun 10, 2016 5:58 am
Cut-Off frequency is usually calculated using the formula:
fc=1/ (2πRC)
PradeepKumar
$16.98
$118.84
5000A Phase Control Capsule Thyristor Convex Type SCR Silicon Controlled Ballast pictureSC36205A02 NEW OLD STOCK
SC36205A02     NEW OLD STOCK picture
