Bluetooth? Screw that. I need USB
Postby nwh212 » Fri Feb 12, 2016 3:11 am
Hey anyone out there reading this. I am not extremely professional. I'm not really at ALL. I bought one of those Atari iPad Controllers about a year ago. I found it recently and undid it, getting out the parts. The thing is, it's set up to use bluetooth. I want to try and set it up to use for games on my computer through USB (I don't have a Bluetooth computer and don't want to buy a crummy little Bluetooth USB receiver)
http://i.imgur.com/BSct5n1.jpg <- this is an image of the circuit board
This is the board. I've highlighted everything I understand (like the buttons and power in/out wires) But what do I do to change it to USB out instead of Bluetooth out?
nwh212
Re: Bluetooth? Screw that. I need USB
Postby pebe » Fri Feb 12, 2016 9:10 am
There is nothing you can do about it.
And what's wrong with a 'crummy' cheap receiver - it will do the job.
Postby PradeepKumar » Fri Apr 29, 2016 6:15 am
You need to go for an alternative as it will not function as per your needs in this connectivity.
PradeepKumar
$27.04
US Stock 154LB 70kg Lifting Magnet Electromagnet Solenoid Lift Holding 59mm 12V picture1PCS NEW GRFY035F20D20 for Proportional Electromagnet 24V Replacement Valves
$375.99
1PCS NEW GRFY035F20D20 for Proportional Electromagnet 24V Replacement Valves pictureDC 12V 0.3A Solenoid Electromagnet Push Pull Type 5N 10mm Open Frame JF-0530B
$13.63
DC 12V 0.3A Solenoid Electromagnet Push Pull Type 5N 10mm Open Frame JF-0530B pictureMAGNETROL AU-12-100 / AU12100 Electromagnet Control
$215.00
MAGNETROL AU-12-100 / AU12100 Electromagnet Control picture
