IDE to SATA with dvd drive
Postby dylanjmartin » Fri May 06, 2011 12:56 am
Hi, i have an IDE to SATA [url]http://www.newegg.ca/Product/Product.aspx?Item=N82E16812186078&cm_re=sata_to_ide-_-12-186-078-_-Product[/url] connecting my dvd drive which is an LG GDR-8162B. I have everything setup properly i'm pretty sure. My computer installed the drivers and shows it in the device manager and bios. I try putting in a disk but it always says there isn't any in there, I tried a music cd, a moive, a game, a burned data disk and even a blank disk, no luck. ive tried setting the adapter and drive to cable select, master and slave modes and still no luck. what do you think is worng, if you think its something is faulty would it be the dvd drive or the adapter, if im doing something wrong what am i dong wrong? thanks ahead of time for your help
dylanjmartin
Postby admin » Fri May 06, 2011 2:41 am
This is a forum for electronics stuff and not for computers. Also I do not think there would anybody who would have tried that particular item to be able to offer help. I suggest you contact the seller and obtain proper support and return it for a refund.
regards,
Admin.
admin
Site Admin
Siemens Panel TP700 6AV2124-0GC01-0AX0 / 6AV2 124-0GC01-0AX0 Original Packaging
$955.99
Siemens Panel TP700 6AV2124-0GC01-0AX0 / 6AV2 124-0GC01-0AX0 Original Packaging pictureSiemens Simovert Masterdrive 6SE7015-0EP50-Z USED
$888.33
$275.00
Siemens Simodrive LT-Modul 6SN1124-1AB00-0AA1 pictureSiemens 6ES7212-1AG50-0XB0 PLC CPU Module 6ES72121AG500XB0 New DHL Shipping
$168.54
Siemens 6ES7212-1AG50-0XB0 PLC CPU Module 6ES72121AG500XB0 New DHL Shipping picture
