Saw-tooth oscillator
Postby Blunderland » Thu May 26, 2011 4:50 pm
http://www.electronic-circuits-diagrams ... ages/2.gif
I keep trying to build this schematic. I put an LED on the output to check whether it's working it lights up but then when I output to a speaker I get no saw tooth wave.
Are both resistors 2.2k? And what uF should the capacitor be? Also if I wanted to use a pot to change the pitch which resistor would I replace?
Blunderland
Postby pebe » Fri May 27, 2011 8:58 pm
Your problem is that the circuit does not provide enough power to drive a loudspeaker. You need to connect it to the input of an amplifier like an LM386, and connect your loudspeaker to the output.
The frequency (pitch) of the output depends on R and C. The BC557 in your circuit is configured as a constant current source that charges C, so frequency will also depend on the supply voltage. With a 2.7V zener the voltage across R will always be 2V when the transistor is conducting, so if you make R = 1K then it will pass 2/1000 = 2mA. If you make supply = 9V then C will have to charge 3V each time.
Assuming the discharge time is short and can be ignored, then the frequency can be calculated from
F= I/(C x V) = 2mA/(1millionth x 3) = 500Hz. Increasing R or C will reduce the frequency and vice versa. Don't reduce R below 100ohms.
I hope that helps.
$139.00
Shark Stratos Cordless Vacuum, Clean Sense IQ & DuoClean PowerFins (Refurbished) pictureNEW Hoover CH93619 40V Cordless Backpack Vacuum MISSING BATTERY/ CHARGER & HOSE
$189.99
NEW  Hoover CH93619 40V Cordless Backpack Vacuum MISSING BATTERY/ CHARGER & HOSE pictureProTeam GoFit 3 Corded Bagged Backpack Vacuum w/ Tools Sternum Clip
ProTeam GoFit 3 Corded Bagged Backpack Vacuum w/ Tools Sternum Clip pictureCordless Vacuum for DeWalt 20V Battery,5 in 1 Handheld Electric Vacuum Cleaner
$54.90
Cordless Vacuum for DeWalt 20V Battery,5 in 1 Handheld Electric Vacuum Cleaner picture
