My oscillator only works with the battery backwards?
Postby Supermario1 » Mon Jun 13, 2011 3:54 pm
I am using a normal 9v battery connector to power a simple breadboarded 741 IC square wave oscillator circuit. This is my very first circuit, and I immediately noticed that it did not work unless I put the leads on the battery backwards...? This must be some simple silly thing I did, but I would really like some help on this... Thanks!
Supermario1
huh
Postby Supermario1 » Mon Jun 13, 2011 8:08 pm
I guess I must have wired +9v and ground backwards, heh. Terribly stupid of me.
Supermario1
Postby jamesjohn » Tue Jun 14, 2011 7:38 pm
Dude how is that possible? it works with the battery upside down.
jamesjohn
mistake
Postby felix05 » Thu Aug 18, 2011 7:24 am
you should have connected the positive and negative in reverse way.
so soldering it correctly. Be careful in feature circuit board creation.
[url=http://www.imtpconsultants.com/]UK education in india[/url]
felix05
$7.77
$400.00
Macurco CM-6 Low Voltage CO Carbon Monoxide Fixed Gas Detector & Controller pictureBierer Meters AV40 40kV Voltage Detector Non-Contact Audible/Visual Proximity
$300.00
Bierer Meters AV40 40kV Voltage Detector Non-Contact Audible/Visual Proximity pictureLincoln Variable Voltage PC Board Assembly L5394-2
$380.00
