Oil level sensor
Oil level sensor
Postby Allycat » Mon Jul 04, 2011 4:52 pm
Hi, I would like to make a sensor Ultrasonic or otherwise that will detect the oil level in an oil pan (sump). I would need to know if the oil level is at the minimum level and also detect if there is too much oil. Any ideas greatly appreciated.
Allycat
ask the Businessman where you buy
Postby leana » Thu Jul 28, 2011 3:05 am
You can ask the Businessman where you buy it.
leana
$17.92
$40.50
$225.00
$11.06
