Help with 120v electronic switch
Postby hapinesiswin » Tue May 31, 2011 4:40 pm
I need a 120v volt switch that when it receives power shuts off power to another source. I have no idea what such a device is called so any help would be greatly appreciated. Thanks for your time!
hapinesiswin
Postby admin » Wed Jun 01, 2011 9:14 am
You can use a 120V relay and connect the load to the normally closed contacts of the relay.
regards,
Admin.
admin
Site Admin
Postby Mike Paul » Thu Jul 28, 2011 1:46 pm
Hello,
You can use 120v rocker switch, which is mainly used in instrument, home appliances and electronics.120v rocker switch receives power shuts off from other source.
Thanks a lot
Mike Paul
Mike Paul
Re: Help with 120v electronic switch
Postby LordStDennis » Sat Jul 30, 2011 11:41 pm
[quote="hapinesiswin"]I need a 120v volt switch that when it receives power shuts off power to another source. I have no idea what such a device is called so any help would be greatly appreciated. Thanks for your time![/quote]
How about a DPST - Double Pole, Single Throw switch? When you throw the switch, the other circuit is opened up. Sound Good?
Grace, Peace & Love,
Lord Saint Dennis Charles Smart
Heaven's Spokesman & Exorcist
LordStDennis
$75.00
$39.95
$174.99
Parker GP600 G-23 77310 Brass Solenoid Valve 120V 9W Sukup Grain Dryer USA pictureOMKC-2 SPORLAN SOLENOID COIL 208-240V NEW
$39.73
OMKC-2 SPORLAN SOLENOID COIL 208-240V NEW picture
