Total noob wanting to undertake custom laser tag project
Postby PsychoThruster » Fri Oct 14, 2011 6:23 pm
Okay, so I have a pretty ambitious vision for a laser tag system and would like to know what material I need to read/watch in order to learn the skills required to approach this project. It will use basic laser tag IR sender/receiver to shoot and and register hits. I would like to add a few neat twists however, such as using a removable and rechargeable battery that will double as an ammunition clip. As in reloading requires swapping out for a new battery. Say 50 shots per battery. I also want to run LEDs and speakers for effects. An ammunition display would be nice too. I realize this probably branches into several different areas of expertise, and this does not concern me as I am prepared to dedicate the time required to learn. I simply need pointing in the right direction. So if any of you could recommend some good books or videos on the subject for a total beginner, I would greatly appreciate it. Thank you.
PsychoThruster
Postby newtonph » Tue Oct 25, 2011 1:01 pm
That's revolutionary for laser tagging game and technology. That's too advance for me, good luck on looking..
newtonph
ASCO HV2647003 Solenoid Valve 3/8” 24 VDC (Box 26-063)
$80.00
ASCO HV2647003 Solenoid Valve 3/8” 24 VDC (Box 26-063) pictureSolenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000
$39.95
Solenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000 pictureNEW NUMATICS 11SAD411EE000061 SOLENOID VALVE 150PSI WITH 226-411B 24VDC 6 WATTS
$50.00
NEW NUMATICS 11SAD411EE000061 SOLENOID VALVE 150PSI WITH 226-411B 24VDC 6 WATTS pictureOMKC-2 SPORLAN SOLENOID COIL 208-240V NEW
$39.73
OMKC-2 SPORLAN SOLENOID COIL 208-240V NEW picture
