What does this OpAmp circuit do?
Postby mhsn » Tue Nov 08, 2011 5:15 pm
I have a board to measure resistance of a dental canal.
I want to know what's the exact job of elements in this circuit.
The PCB:
[url=http://www.hotimg.com/image/aY2DCpE][img]http://t.hotimg.com/ts/aY2DCpE.png[/img][/url]
Schematic from PCB:
[url=http://www.hotimg.com/direct/8XUzURZ.png][img]http://t.hotimg.com/ts/8XUzURZ.png[/img][/url]
My idea about the above SCH:
I think U2A(upper section) is generating a non-DC signal and feeding it to the JL(Lead/Probe) and the lower part is converting the AC to DC with suitable amplification.
So I rearranged the SCH as follow:
[url=http://www.hotimg.com/direct/yTdKMs2.png][img]http://t.hotimg.com/ts/yTdKMs2.png[/img][/url]
Now what do you think about this circuit?
Please share your ideas with me, I know the analog men will solve this. :)
Very thanks in advance.
[url=http://www.i-s.ir]http://www.i-s.ir
پروژه های الکترونیک میکروکنترلر[/url]
mhsn
hey I am new here.
Postby embalaskala » Tue Nov 08, 2011 5:44 pm
Hey I'm new here at www.electronic-circuits-diagrams.com[url=http://www.carpet-cleaning-lasvegas.com].[/url] I only wanted to say greetings to all.
embalaskala
Re: hey I am new here.
Postby mhsn » Tue Nov 08, 2011 5:49 pm
[quote="embalaskala"]Hey I'm new here at www.electronic-circuits-diagrams.com[url=http://www.carpet-cleaning-lasvegas.com].[/url] I only wanted to say greetings to all.[/quote]Me too! Thanks anyway
mhsn
$27.04
$85.00
$13.63
DC 12V 0.3A Solenoid Electromagnet Push Pull Type 5N 10mm Open Frame JF-0530B picture12V 24V DC 2.5-150KG Electric Lifting Magnet Electromagnet Solenoid Holding Coil
$38.44
12V 24V DC 2.5-150KG Electric Lifting Magnet Electromagnet Solenoid Holding Coil picture
