Constant Current Regulator
Postby power_speed » Fri Nov 18, 2011 1:34 am
Hello all,
New to this forum, so I say howdy.
I am looking for a nice simple and easy design, for a current regulator.
I need it to output 14vdc at 20 amps.
The trick is I don't want it to shut down when the 20 amps is reached, I want it to continue providing the full 20 amps but no more. Also variable current under the max amperage is needed based on load.
Please Help a newbie.
Robert
power_speed
I found this one
Postby power_speed » Sat Nov 19, 2011 1:49 pm
Can anybody suggest a good op amp for my above mentioned purpose.
Here is the link to what might work.
http://www.ecircuitcenter.com/circuits/ ... r_src1.htm
power_speed
Postby I_Daniel » Sun Nov 20, 2011 11:56 am
a cheap 741 Op Amp is ideal this purpose.
100 COMMERCIAL CRYSTAL 10 LB LBS 1.5 MIL Plastic Ice Bag Bags With Drawstring
$20.50
100 COMMERCIAL CRYSTAL 10 LB LBS 1.5 MIL Plastic Ice Bag Bags With Drawstring pictureDental ZIRC CRYSTAL HD Neon Mouth Mirrors with Soft Grip Handle - MADE IN USA
$145.00
Dental ZIRC CRYSTAL HD Neon Mouth Mirrors with Soft Grip Handle - MADE IN USA pictureScintillator Crystal CsI(Tl) 10x10x10 mm for DIY gamma spectroscopy with SiPM
$49.00
Scintillator Crystal CsI(Tl) 10x10x10 mm for DIY gamma spectroscopy with SiPM pictureBorescope Camera with Light, 16.5ft Endoscope Inspection,Waterproof Snake Camera
$29.99
Borescope Camera with Light, 16.5ft Endoscope Inspection,Waterproof Snake Camera picture
