Alpha numeric display question
Postby mattsaloeltjen » Sat Nov 19, 2011 9:30 pm
I'm building a Jukebox out of a, Well a jukebox. The cabinet has a display in it but with the control board missing I was thinking it would be neat to display some information on the display. What I'm looking for is something programmable, that could drive this board. I will post the schematics of the original display also I have the control board schematics too. Just so were clear I have the board attached to the display, I do not have the control board that was the brain of the Jukebox.
2011-11-19 14.50.49.jpg (1.89 MiB) Viewed 9122 times
2011-11-19 14.50.02.jpg (1.93 MiB) Viewed 9122 times
mattsaloeltjen
More pictures
Postby mattsaloeltjen » Sat Nov 19, 2011 9:40 pm
This is the display driver on the CPU bottom of page
2011-11-19 14.53.28.jpg (1.12 MiB) Viewed 9121 times
mattsaloeltjen
This is the box
Postby mattsaloeltjen » Sat Nov 19, 2011 11:55 pm
Just to show off a little :P
2011-11-19 14.56.31.jpg (947.55 KiB) Viewed 9118 times
2011-11-19 14.56.23.jpg (1.34 MiB) Viewed 9118 times
mattsaloeltjen
Re: Alpha numeric display question
Postby Drew1 » Sun Dec 18, 2011 11:51 pm
Wow...a person would have to really study up and have intimate knowledge of the architecture and operation of this circuit in order to customize it to do what you are asking. Your best bet would be to find a replacement for the control board. They may or may-not be available. Do you know what happened to the one that was installed?
Drew1
Postby JMACgyver » Fri Jan 13, 2012 12:28 am
I agree with Drew; it would take very detailed knowledge of the original or similar circuitry.
Now, options:
Try going secondhand to find a compatible control board. there are a number of vending machine repair forums that might have people selling parts from such machines. Set up a saved search on ebay to email you when it finds items like it.
Or, I would try putting in one of those programmable scrolling message signs (with input from the comp as to the content to put on the sign.
Maybe even just stick some LCD Display modules under there. I'm sure some of them can be controlled directly from an I/O port on the comp (i.e.: USB, Serial/RS-232, Parallel, etc)
In all cases though, I would definitely wire up the keypad selection circuits to a normal PC keyboard (if you havent already) and set up a macro or script to interpret which buttons/keys do what.
Thanks for sharing this project with us, but definitely also share it with the vending forums and perhaps programming or embedded control forums as well.
Good Luck with it!
--Electro--
aka The Other David
Procrastinators Unite!
Tomorrow!
JMACgyver
$13.49
$130.00
Salisbury 21405WT16 Dielectric Overboot 20 KV Size 16 17 Inch Tall, Deep Heel pictureLineman Servus Super Dielectric Overshoes Mens Size 8 Brand New Read Lot L
$54.95
Lineman Servus Super Dielectric Overshoes Mens Size 8 Brand New Read  Lot L pictureRFS Manual Grounding Jacket Striping TOOL RFS-916423 RFS 916423 JSTRIP-114
$249.99
RFS Manual Grounding Jacket Striping TOOL RFS-916423 RFS 916423 JSTRIP-114 picture
