control model planes using speech recognition
Postby nevlogic » Sun Nov 20, 2011 12:30 pm
is it possible to control model planes using speech recognition? if it's possible, what kind of knowledge to i need to pull it off?
nevlogic
Postby pebe » Sun Nov 20, 2011 1:19 pm
Most radio controlled planes are directionaly unstable, and need to have constant correction applied to their control surfaces. With digital control these updates are sent every 20ms.
It is highly unlikely that anyone could achieve that sort of control with a speech recognition system.
Postby nevlogic » Sun Nov 20, 2011 1:24 pm
i was thinking of like say u want the plane to go up so you say : elevator 10 degree. And when u think it climb enough u say: elevator 0 degrees. that kind of u see and u control type
nevlogic
Postby pebe » Sun Nov 20, 2011 1:59 pm
What instruction would you give when it started to roll?
Postby nevlogic » Sun Nov 20, 2011 8:55 pm
sorry i am just a noob. what do u mean?
nevlogic
Postby pebe » Sun Nov 20, 2011 10:10 pm
Surely you know what a roll is? It's when one wing starts to drop. If left in that condition the plane will go over onto its side, then its back and head earthwarrds with disastrous results.
When flying a model you have to make continuous adjustments of the aileron control to correct for either wing dropping. They are continuous small adjustments and you would not have time time make a series of spoken commands like left, stop, left, stop, right, stop, right,...etc and have speech recognition convert them to commands. At the same time you need to make corrections for the elevators, and the rudder, maybe?
They would all be much too slow.
Postby nevlogic » Sun Nov 20, 2011 10:22 pm
oh. hmm true.. then is it possible to make it semi voice control? example u still use voice command but with the help of a controller. so example u say : roll right 10 deg. and if there is any changes needs to be made to the alierons/ elevator u do it on the controller?
nevlogic
Postby pebe » Sun Nov 20, 2011 10:29 pm
No, that would be far too complex to be housed in an RC plane
Re: control model planes using speech recognition
Postby aadambell » Mon Dec 05, 2011 1:34 pm
“Is it possible to control model planes using speech recognition? If it is possible, what kind of knowledge do you need to pull it off?”
I hope you know radio controlled planes are unstable with their control surfaces constantly ‘yelling’ for constant corrections! Via digital control, these updates are sent and received every 20ms. Such control is usually rare via a speech recognition system.
aadambell
15Values 750pcs TO92 Transistors Assortment Kit PNP NPN Bipolar, General Purpose
$9.22
15Values 750pcs TO92 Transistors Assortment Kit PNP NPN Bipolar, General Purpose picturePower Transistor, Mosfet, Thyristor and Voltage Regulator Assortment Kit, 82
$54.99
$6.35
3pcs 2N3055 / TRANSISTOR / CROSSES TO ECG130,NTE130 / TO3 pictureMJ15024 To-3 Silicone Audio Power Output Transistor 10 Pack
$39.99
MJ15024  To-3 Silicone Audio Power Output Transistor 10 Pack picture
