Volatile Memory question
Postby pebe » Mon Nov 21, 2011 8:13 am
Hi David,
I'm pleased it's all working for you.
Re: Volatile Memory question
Postby aadambell » Mon Dec 05, 2011 1:30 pm
I second Pebe here. There should be a switch putting it immediately into standby mode. A micro consumes minimal current in standby, where as the capacitor across the battery leads should probably suffice for the task you are trying to undertake.
aadambell
Previous
$149.00
$565.00
$799.99
SOLAR ELECTRONICS MODEL 8012-50-R-24-BNC LINE IMPEDANCE STABILIZATION NETWORK pictureData Inc Model 2124 Differential Amplifier High Gain High-Impedance Inputs
$211.95
Data Inc Model 2124 Differential Amplifier High Gain High-Impedance Inputs picture
