load cell input on thyristor input
Postby electrichg » Wed Nov 30, 2011 12:32 am
I have a project on which I am using a data logger.
The data logger has spare inputs for temperature that I am not using. I need to log the out put from a load cell (0.5v-4.5v) but the data logger does not have an input for this.
Is it possible to design a circuit that make the 0.5vto 4.5v output from the load cell appear like a 30k to 0.67k out put from a negaative temperature coeficient thyristor so that I could log the load cell on a temperature input?
0.5v~30k
4.5v~0.67k
control voltage 5v
1/R proportional to loadcell output
Tom
electrichg
Re: load cell input on thyristor input
Postby Thomas W » Sun Dec 04, 2011 3:36 pm
Here's an application note from Maxim:
"Digital Pots Achieve Voltage-to-Resistance Conversion"
[url]http://www.maxim-ic.com/app-notes/index.mvp/id/3284[/url]
Thomas W
MUFASHA Non-Contact Voltage Detector Electrical Pen AC Voltage Tester Smart Brea
$24.00
MUFASHA Non-Contact Voltage Detector Electrical Pen AC Voltage Tester Smart Brea pictureMacurco CM-6 Low Voltage CO Carbon Monoxide Fixed Gas Detector & Controller
$400.00
$380.00
Lincoln Variable Voltage PC Board Assembly L5394-2 pictureAutomated Logic SE6104SP BACnet Control Module SE6104SP HVAC Controller
Automated Logic SE6104SP BACnet Control Module SE6104SP HVAC Controller picture
