Hello All.
The bottom diagram shows what were currently using, minus the diode circled in RED. The profet is actually a mosfet. When we short out the contacts ( say a light bulb )the transistor turns the LED on which indicates continuity. We then turn the mosfet on to light up the light bulb. The current system runs on a 12v Dc supply. The new system runs of a 9 volt battery. We have a DC to DC step up converter, 9 volts in - 30 volts out. Were a bit concerned that the 30 volts may go back up through the transistor to the 9 volt supply line and damage the rest of the electronics. A blocking diode with the RED circle placed in the circuit will help solve this problem. I have actually made a mock up of this circuit without the blocking diode and it works but someone told me that eventually the transistor will die over time. Is this true......The circuit is only turned ON for one second and used no more than once a week. So the question is, would you use the diode or not.
