IR photo gate to delay timer.
Postby dbalfour » Tue Mar 06, 2012 3:46 pm
Hey there I am connecting a IR photo gate kit to a delay timer made on a breadboard.
The output of the IR photo gate is a PCB 3-way Terminal block with markings NO/OM/NC (left to right) and I am not quite sure of where to connect these wires to my delay timer kit.
Can someone give me any tips becuase whenever I search on google for PCB terminal blocks its only sales on them and nothing to do with how to use them or connect them.
dbalfour
Re: IR photo gate to delay timer.
Postby pebe » Tue Mar 06, 2012 4:57 pm
The terminals are probably the output of a relay.
The centre contact should probably have said 'COM' - not 'OM', ie. the common terminal. NO would be the normally open contact and NC the normally closed contact
$27.04
$13.63
$375.99
1PCS NEW GRFY035F20D20 for Proportional Electromagnet 24V Replacement Valves pictureSDC Electromagnetic 650 LB Lock 1581SNDV Exit Check Delayed Egress System
$85.00
SDC Electromagnetic 650 LB Lock 1581SNDV Exit Check Delayed Egress System picture
