LED matrix board
LED matrix board
Postby navinchandra » Sun May 13, 2012 9:15 am
I want to make LED dot matrix (10x200) and (16x120) to be used as a moving light display. (I have ready built controller unit which can drive up to maximum 2048 pixles and up to 30 fps. I will design the PCB. I want only configuration.
72 yr old, retired person and electronic hobbiest.
navinchandra
Re: LED matrix board
Postby Major_Problem » Thu May 24, 2012 6:47 pm
Major_Problem
Thermo Dionex NCS-3500RS Loading Pump Purge Unit Pressure Transducer 6042.71
$210.00
Thermo Dionex NCS-3500RS Loading Pump Purge Unit Pressure Transducer 6042.71 pictureSiemens 545-208 Analog Output Pneumatic Transducer
$550.00
$169.99
$499.99
