LED grow light
LED grow light
Postby darkwhamsic » Tue May 22, 2012 9:41 pm
I recently got one of those LED grow lights from ebay, like >>http://www.ebay.co.uk/itm/225-LED-Hydroponic-Plant-Grow-Lighting-Panel-Board-Blue-Red-Lamp-Light-UK-240V-/251063703695?pt=UK_HomeGarden_Garden_PlantsSeedsBulbs_JN&hash=item3a7490188f
However, it seems to be being a bit a a pain and not working properly (they have refunded me for the product and i dont have to send it back, so thought i'd have a play and see if i can get it working)
I'll start from the beginning (good place i think)
when i went to turn on the lights, i though they weren't on at all so changed the fuse, however i noticed they were on, but very, very dull. so it wans t the fuse
so i took the back off to have a look inside. There are 2 boards inside, one with all the resisters etc, the other with just the LEDs on, to make sure nothing was causing a problem inside. I re-soldered the positive wire to the LED board cause it looked a little loose amd the same with the smaller board/
Still nothing
But by accident, i noticed that when i touched the back of one of the LEDs it would light up that row... hmm strange
It doesnt smell like anything has burnt inside, and i cant see any burn marks on any boards
All the LEDs are working.. in a fashion..
Just wondered if anyone has any suggestions as to waht it might be or how to get it working again
I'll try and put a pic of the curcuit if needed
darkwhamsic
Re: LED grow light
Postby I_Daniel » Wed May 23, 2012 7:23 am
When you touch something and it works then you have a very difficult fault to trace, namely a dry joint, sometimes there is also a hairline crack which when you touch or press on a pc-board makes contact.
Re: LED grow light
Postby darkwhamsic » Wed May 23, 2012 5:30 pm
[quote="I_Daniel"]When you touch something and it works then you have a very difficult fault to trace, namely a dry joint, sometimes there is also a hairline crack which when you touch or press on a pc-board makes contact.[/quote]
Will have a look through at the solders see how they are.
Is there a 'good' way of looking for and cracks.. like giving the boards a little flex, or could that just make it worse
darkwhamsic
Re: LED grow light
Postby I_Daniel » Thu May 24, 2012 9:28 am
Occasionally you will see a tiny oxide coloured ring around the lead. which could. but not for certain indicates a dry joint.
Two other ways to check
1st check with a volt meter from one joint to the other along a track. But bit dangerous you could cause a short if you are not very careful.
2nd way rather use a Ohm meter and check from one joint to the other across a track. The Power must be off.
Re: LED grow light
Postby Major_Problem » Thu May 24, 2012 6:24 pm
A simple way of supplying LED's is connecting a lot of them in series with one series resistor. Probably per column. If all LED´s are low in output, a power supply problem (low voltage) seems the first item to check.
I took a look at the e-bay site. It's a 240 V light panel. Does it use a straight forward adapter for power supply? What is the voltage on the output?
Every LED needs approx 1.5 to 4 Volt across, depending on LED colour. Count the number of LED's in series, add some voltage for the resistor and you know the minimum voltage of the adaper.
if you know the resistor value, use U=IxR to calculate the voltage across resistor (e.g. 0.01 Amp x 470 ohm = 4.7 Volt).
Major_Problem
Re: LED grow light
Postby Leroy Asad » Mon Aug 20, 2012 8:21 am
It is important not to connect the LEDs in parallel as it would lead to their ultimate failure. Keep the two branches of series connections and measure voltage across each LED and the voltage across resistor and post it here. I think the LEDs are dropping much more voltage than specified.
_______________________
[url=http://www.ledstrips8.com/led-light-bulbs-c-1.html]led light[/url]
[url=http://www.ledstrips8.com/]led strip lighting[/url]
[url=http://www.ledstrips8.com/led-fluorescent-tube-replacement-c-9.html]fluorescent led bulbs[/url]
Leroy Asad
MSA Galaxy GX2 Multi-Unit Charger 10127422 Altair 4/4X Factory Sealed Dock USA
$399.88
MSA Galaxy GX2 Multi-Unit Charger 10127422 Altair 4/4X Factory Sealed Dock USA pictureMSA 10106727 ALTAIR 5X Sulfur Dioxide (SO2) XCell Replacement Sensor Kit-2026
$600.00
MSA 10106727 ALTAIR 5X Sulfur Dioxide (SO2) XCell Replacement Sensor Kit-2026 pictureMSA Galaxy GX2 Automated Test System, Cylinder Holder, Altair/Altair Pro, 5/5x
$675.00
MSA Galaxy GX2 Automated Test System, Cylinder Holder, Altair/Altair Pro, 5/5x pictureMSA Altair 4XR 4-Gas COMB/EX LEL, O2, H2S & CO Monitor detector
$450.00
MSA Altair 4XR 4-Gas COMB/EX LEL, O2, H2S & CO Monitor detector picture
