power supply comparison help
Postby gary2 » Tue Sep 11, 2012 1:27 pm
The reason I'm here is to double check on the specifications compatibility of two power supply's before I spend my money.
I have a six year old LaCie external hard drive unit with a failed power supply. The original power supply has been discontinued. LaCie offers a replacement power supply for sale but the power output specifications don't match the original. I hope that someone can give me a definitive answer to buy or not buy or point me toward somebody who can help me.
The original power supply:
AC Input: 110V / 220V
DC Output: 12V 2.2A 26.4W / 5V 2.0A 10W
The replacement power supply:
DC Output: 12V(3A) / 5V (4,2A)
Thanks in advance for your help.
Gary
gary2
Re: power supply comparison help
Postby pebe » Thu Sep 13, 2012 4:22 pm
The voltage ratings of both are the same.
The new one has a higher current capability, but as you hard drive will only take the current it requires, the new one you propose will be quite OK.
Johnson Controls METASYS VAV Control Module VMA1615 24V 15A
$35.00
Johnson Controls METASYS VAV Control Module VMA1615 24V 15A pictureJohnson Controls Metasys DX-9100-8454 Extended Digital Controller Rev B
$35.99
Johnson Controls Metasys DX-9100-8454 Extended Digital Controller Rev B pictureMetasys N30 Supervisory Controller Base Unit N2 Field Bus Ethernet MS-N301310-1
$320.00
Metasys N30 Supervisory Controller Base Unit N2 Field Bus Ethernet MS-N301310-1 pictureMetasys Johnson Controls (lot of 12) AP-VMA1420-0 coupling/bushing AP-VMA1410-0
$49.99
Metasys Johnson Controls (lot of 12) AP-VMA1420-0 coupling/bushing AP-VMA1410-0 picture
