sending data and power on just 2 wires
Postby casdsys » Mon Sep 17, 2012 5:07 pm
Does anyone know how ( serial ) data and power can be sent on just 2 wires, were talking about DC voltage. If anyone can point me in the right direction that would be great, thank you.
casdsys
Re: sending data and power on just 2 wires
Postby I_Daniel » Wed Sep 19, 2012 7:22 am
I can only point not really help.
Consider a satellite dish and decoder. DC voltage is provided via the antenna socket of the decoder to the receiver on the dish. The RF signal, with it's digital encoding. is also sent along the same co-ax (Two wires ie. 1. The core. 2. The braiding surrounding the core.)
I must assume that the RF or digital signal is taken off the DC supply via a small capacitor. The braiding of the co-axial cable would normally be the common earth ( vcc -) connection.
$27.04
$13.63
$85.00
SDC Electromagnetic 650 LB Lock 1581SNDV Exit Check Delayed Egress System picture1PCS NEW GRFY035F20D20 for Proportional Electromagnet 24V Replacement Valves
$375.99
