Tilt Sensor Circuit
Tilt Sensor Circuit
Postby wfrench » Fri Oct 05, 2012 8:22 pm
I'm trying to design a circuit/product for my degree that checks that an angle is correct. EG. an incline of a slope/ladder etc is correct (say between 25 - 30 degrees) and if it is outside the limit a buzzer goes off. Maybe even have a display to show the angle. I'm trying to do this on a tight budget, i have looked into tilt sensors but the only cheap ones I have seen are the trigger ones with either a ball or tilt switch, is there anything programmable or customizable?
Does this make sense, I am competent in soldering and know the basics, could someone put me in the right direction, any existing circuits out there?
Will
wfrench
Re: Tilt Sensor Circuit
Postby pebe » Sat Oct 06, 2012 5:52 am
You could try an accelerometer like this:
http://www.ebay.co.uk/itm/2x-MMA7660-Th ... 4ab8108e02
It gives outputs on three axes although you only need one. But who cares? It's cheap anyway.
There is an output due to gravity when the chip is at rest, which will be sinusoidal through 360º. The output is digital so is easily measured with a micro to give the detection you want.
Postby wfrench » Sat Oct 06, 2012 8:34 pm
Ahh thanks, I had been looking down that route, where could I start in trying to design a circuit? are there schematics of existing systems/tutorials?
Will
wfrench
Postby pebe » Wed Oct 10, 2012 4:24 pm
I Googled for application notes and this is one that came up.
http://resenv.media.mit.edu/classes/MAS ... mx-001.pdf
It looks to be a good starting point.
$5.99
10PCS Rotary potentiometer linear 15MM 1K 2K 5K 10K 20K 50K 100K 250K 500K 1M pictureAllen Bradley 800T-U29 Potentiometer 800TU29 Series Q
$170.00
Allen Bradley 800T-U29 Potentiometer 800TU29 Series Q picture5 Set linear Potentiometer Kit 15mm 3Pin B1K 2K 5K 10K 20K 50K 100K 250K 500K 1M
$6.47
$125.00
Cavitron power potentiometer for Gen 131, 132, 136, 137 picture
