MQ8 H2 Sensor circuit
Postby heavyhank » Mon Nov 19, 2012 9:57 am
I'm trying to tackle a 'failsafe' problem with the following circuit http://dlnmh9ip6v2uc.cloudfront.net/dat ... c/MQ-8.pdf
In Fig.2.
The Vout is wired to an ADC chip, which then sends a digital signal to the unit telling it if any H2 has been detected. The unit will detect if the sensor module is not plugged in, so I'm guessing it is a normally closed position on the unit (if the sensor isn't plugged in, the position is open and the unit will not start up. So, in a way, this is a failsafe of sorts. However, I've a number of sensors which do not detect H2 yet will still close the circuit - I assume the heater coil has failed therefore the sensor doesn't reach the required temp for it to pick up H2.
My question is, how can I introduce a circuit that will give a similar Vout signal to the ADC if the heater fails?
I'm not an engineer, so please give me laymans terms if you can.. Thank you!
heavyhank
Re: MQ8 H2 Sensor circuit
Postby pebe » Mon Nov 19, 2012 11:02 am
Have you included the pot, RL ?
Postby heavyhank » Mon Nov 19, 2012 1:02 pm
Yes, as far as I know...
heavyhank
Postby heavyhank » Mon Nov 19, 2012 1:05 pm
Really, I suppose what I need is for the circuit to open in the event of a heater failure.
I'm not sure how this will be possible as A - B will always be connected. As I said, I'm no engineer..But I had thought if the heater fails, perhaps if I introduce a similar voltage to the ADC then I can trigger the same error as thought the sensor had detected H2. I can't see how else I could do it..?
heavyhank
Postby pebe » Mon Nov 19, 2012 7:25 pm
There is nothing in the data sheet that gives details about heater failure.
Could you use a multimeter to measure the resistance A to B with no heater volts applied and let us know the result?
$53.99
$90.00
EMERSON SOLA SDP 5-5-100T POWER SUPPLY picturePower Supply with Bracket 4500-PS
$60.00
Power Supply with Bracket 4500-PS pictureMean Well NMP650 - EHKK-03 Power Supply with 12V , 24V , 48V Outputs
Mean Well NMP650 - EHKK-03 Power Supply with 12V , 24V , 48V Outputs picture
