by pebe » Sat Aug 25, 2012 1:54 pm
Ok Garry. Here is the circuit. I have drawn it in colour to make it more readable.
On the left is the radio receiver. There are two relays marked A and B (I assume that the letters correspond with the letters on the two buttons on the transmitter, and that you will use A for ‘open’ and B for ‘close’). At the right is the 12V 3A power supply (I have not shown the mains power connection).
The 6 terminals at the bottom are the connections to the two relays that I have shown the wiring and motor connections for. ‘C’ is the common contact, ‘NO’ is the contact that is normally open, and ‘NC’ is the normally closed contact. You can see that the motor is connected between the two ‘C’s. As drawn, the door has closed and opened the bottom limit switch. No button is being pressed so both sides of the motor are normally connected through the relays to the –ve supply (assuming you purchased the receiver with the 'momentary' type of action), and the motor is stopped.
When you press the A button on the transmitter, relay A will change over so C connects to NO instead of NC. 12V is then applied to the left side of the motor via S1 and NO/C. As the right side is at 0V through C and NC, the door will start to open, and S2 will close. When the door gets to the top the top limit switch, S1, will open and stop the motor. When you release the button the relay will revert to normal. When you press the B button 12V will be applied to the right side of the motor so it will run in reverse, closing the door until the bottom limit switch, S2, opens.
D1 and C1 may not be necessary. I have included them because I don’t know what the starting current of the motor is. If it high enough to make the 12V supply voltage dip, then C1 will stop that dip being passed to the receiver and giving erratic radio reception. I suggest you try first without them (link across D1). The capacitor, C2, is to suppress any electrical noise from the motor brushes. Again, that may not be necessary and you could try at first without it.
The antenna of the radio receiver as supplied is coiled up. As you are using it at close range you could leave it like that. But if there are any reception problems, then uncoil it.
Check that the A (open) button actually works the A relay by measuring continuity between C and NO when the button is pressed, otherwise the limit switches will need to be transposed. When you are ready, set the door in the half open position and press the A button and check that the door opens. If it closes instead of opening, reverse the connections to the motor to change its direction.
I hope I’ve covered everything. Best of luck with your project!
- Attachments
- Cat Door.GIF (6.8 KiB) Viewed 29666 times
