design help for a old problem
Postby ronb11 » Wed Dec 05, 2012 2:31 pm
Hi, my names Ron and I am new to this forum and looked it up to see if I might get some practical advise on a simple problem that I am trying to resolve.
The problem involves condensation buildup on the inside of my residential windows due to inadequate air circulation over the window area. A brief bit of info before I continue, we do not have forced air ducts or return air grills. The home is heated with a natural gas fireplace, vaulted ceilings with fans, 1000 sq.ft,
windows are fairly new, argon filled.
The idea I have in mind is to construct a device similar in design to a hair dryer. A low voltage fan (variable rpm) installed in a tube or case that will also contain a heating element. This unit would then be able to deliver a small, quiet warm air flow over the window surface that should reduce condensation on the window to a degree.
Has any one heard of a device that can do this ? Any suggestions or ideas as to whether or not this might work? I have a bit of experience in electronic design and electrical circuits as well as a machining background. It would be really great to hear what you all have to say!!! Thanks
ronb11
Re: design help for a old problem
Postby pebe » Fri Dec 07, 2012 5:34 am
Hi Ron,
I don't understand why you have posted your question here, in an electronics forum, when your problem is a physical one and could have been better dealt with in a DIY forum such as this:
http://www.diybanter.com/
That said, it would appear, especially with double glazed windows, that the room suffers from an excess of humidity that could be helped with just a fan to give better circulation. But with an open hearth gas fire have you got an adequate supply of outside air coming in through a proper vent? If not there could be a build-up of carbon monoxide, and that is dangerous.
Postby WardC » Sat Dec 08, 2012 3:42 am
Caution. blowing or heating away the condensation will waste tremendous energy.
Lowering humidity or improving the insulation of the windows (such as covering them with a sheet of plastic - Scotch makes temporary storm windows for such, you tape them around the edges and use a hair dryer to shrink them to be tight and smooth.
Sorry for replying to a Q in the wrong forum. I suggest (1) good paint on the bottom of the window (waterproof) so it doesn't hurt the wood, and thus "live with it"; if you don't want to do something active to lower the humidity or increase the insulation.
WardC
Frequency Drive
$400.00
Frequency Drive picture0.01Hz-200Khz Adjustable Frequency Generator for Healing Schumann Sine Waves Res
$37.99
0.01Hz-200Khz Adjustable Frequency Generator for Healing Schumann Sine Waves Res pictureMicronta 351 frequency counter
$34.99
Micronta 351 frequency counter  pictureVariable Frequency Drive VFD Motor Speed Control Inverter 3 Phase 7.5 KW
$135.00
Variable Frequency Drive VFD Motor Speed Control Inverter 3 Phase 7.5 KW picture
