Will this work?
Will this work?
Postby james199001 » Wed Dec 26, 2012 3:29 pm
Need to know it this circuit will work for a light project in my room it uses a tip 31c transistor 12v led strip a 12v power suply and a sub.
I want the sub to make the lights flash but there is not enough power going to the sub to solder it directly to ther led strip.
Will this layout work or does it need changing, the led strip has built in resistors btw.
[url]http://tinypic.com/view.php?pic=106hqoo&s=6[/url]
james199001
Re: Will this work?
Postby pebe » Wed Dec 26, 2012 6:03 pm
What is the 'sub' and what does it do?
Re: Will this work?
Postby james199001 » Wed Dec 26, 2012 7:17 pm
The "sub" is a Logitech X-530 subwoofer which gives the bass to the music, this is what i want as the "trigger" to make the transister conduct so the leds will flash.
Hope you can understand what i mean.
james199001
Re: Will this work?
Postby JoshMac » Thu Dec 27, 2012 3:03 am
James, are you referring 'sub' to a sub woofer speaker?
JoshMac
Re: Will this work?
Postby james199001 » Thu Dec 27, 2012 9:04 pm
[quote="JoshMac"]James, are you referring 'sub' to a sub woofer speaker?[/quote]
Yes its a Logitech X-530 5.1 surround sound subwoofer
james199001
Re: Will this work?
Postby james199001 » Thu Dec 27, 2012 9:09 pm
made a better looking diagram and added a SPDT switch.
should be a bit easier to understand from this image.[url]http://tinypic.com/view.php?pic=2pydo3k&s=6[/url]
james199001
Re: Will this work?
Postby pebe » Fri Dec 28, 2012 2:00 pm
What is the 3wire symbol above the LED strip?
Re: Will this work?
Postby james199001 » Fri Dec 28, 2012 8:17 pm
[quote="pebe"]What is the 3wire symbol above the LED strip?[/quote]
It is a SPDT switch so the led strip can be on or flash to the music.
james199001
Re: Will this work?
Postby pebe » Fri Dec 28, 2012 10:44 pm
The way it's wired is OK but I don't know whether you may need some resistance in series with the base pin of the TIP31 to limit base current. The spec I found for the Logitech unit says its output is 15.5W and the speakers are hardwired to the base unit, so I don't know how you propose to get at its output.
You need to find out what voltage you will be feeding from it into the TIP31.
Re: Will this work?
Postby james199001 » Sat Dec 29, 2012 12:19 am
[quote="pebe"]I don't know whether you may need some resistance in series with the base pin of the TIP31 to limit base current.[/quote]
I purchased the things i need so i guess it is just trial and error from here on for me.
I can get to the "+"and"-" of the subwoofer so i will wire the "+" of the sub to the base,and the "-" to the emitter.
After reading the manual i have it says the subwoofer is "25 watts RMS into 4ohms at 100Hz at 10% THD clipping"
When i get all of the things in the post i will report back to say if it works or not.
james199001
Re: Will this work?
Postby james199001 » Mon Dec 31, 2012 4:30 pm
Works great here is the test video i made just showing it works [url]http://www.youtube.com/watch?v=unDzyqKEIQ8[/url]
Will post other video later when i am done doing the proper setup.
james199001
Re: Will this work?
Postby james199001 » Mon Dec 31, 2012 6:04 pm
Just finished the wiring, nearly 4 hours of it.
Here is the finished product[url]http://www.youtube.com/watch?v=a3q_8oHTk9o&feature=youtu.be[/url]
james199001
Re: Will this work?
Postby miketaylor » Mon Jan 07, 2013 9:45 pm
Yes Your power suply and a sub is main contected check it first and other wise transistor 12v led strip is perfectly used.
Printinghost.com
miketaylor
$99.99
$105.00
Multifunctional Cheating Smart Calculator 4GB Memory With Video Photo Text Ebook pictureVWR 620-1965 Traceable 6404 Temperature and Humidity Data Logger W/ Memory Card
$59.40
VWR 620-1965 Traceable 6404 Temperature and Humidity Data Logger W/ Memory Card pictureNew In Box INTEL NMA1XBD512GQS Persistent Memory 512GB
$360.25
New In Box INTEL NMA1XBD512GQS Persistent Memory 512GB picture
