MOTOR MADNESS 2013
MOTOR MADNESS 2013
Postby POPSCAN1 » Mon Dec 24, 2012 2:47 am
I need a lot of bright electronic gurus to help me with my recently developed DIFFERENT type electric motor. This motor has hi torque, easy to build, inexpensive, hi rpms, and consumes very little watt power. It certainly is a candidate to power future electric cars. I OPEN SOURCED ALL INFORMATION AS TO HOW TO BUILD IT FOR FREE for all folks world wide.
The motor power box does two things. First-Spins a permanent magnet wheel. The second thing it does is divert a huge coils back EMF into a light dump. Thats where I (we) need expert electronic help. I would like to recover that lost power and put some back into the input of the motor thus closing the loop. A self runner that can power other devices.
The below link will take you to other links as well as a forum link setup by my open source publisher.
Hope to see you there.
Click the below link or click You Tube -- MOTOR MADNESS 2013--
http://www.youtube.com/watch?v=8ODdbquT_Ro
Tom
POPSCAN1
Re: MOTOR MADNESS 2013
Postby pebe » Wed Dec 26, 2012 10:20 am
I think you may get more success if you join the 'free energy' brigade. I think one of the earliest spoofs on such a motor was by Bedini. Since then, many more have followed on Youtube.
One said in an introduction that 'You don't need to be an expert in electronics to build a Bedini motor'. Quite right. It has absolutely nothing to do with electronics - only a blind faith and a blind hope.
There is a law that states that energy cannot be created. It can only be changed from one form to another.
Postby POPSCAN1 » Mon Jan 14, 2013 9:44 pm
My motor/generator is a hybrid mix of many ideas and most components used are of my chosing. As far as FREE energy goes you cant get something out of nothing.
You can however trip a very large force with a small force. IE a blasting cap exploding will set off a dynamite charge.
Dynamite will trigger a atom bomb which trigger a hydrogen bomb.
I have found if you follow most of my links that magnetic power is used to power my particular motor generator.
Magnets are attracted to and repell away from the coil. THE COIL TRIPS THE MAGNETS.
Not the other way around where the coil attracts and repells the magnets. That would setup a huge current demand by the coil.
Now think different kind small version of the Joseph Newman motor and you are on the right track.
POPSCAN1
Postby pebe » Tue Jan 15, 2013 8:38 am
I followed your Youtube link, and it was about what I expected from a title ‘Motor Madness’.
“…….burning off the back EMF of the coil……….”? What mumbo jumbo is that? The camera takes us to the wall socket to show a ‘wall wart’, but what is the other plug for? And there is not the slightest attempt to describe what the lump of electronics with a heat sink is for.
I had never heard of a Joseph Newman motor before, but the description on Wiki shows it for what it is. A device which will allegedly produce more energy than it uses, and for which a patent has been denied.
This posting is nebulous waffle and doesn’t belong in a serious technical forum. Forget about it!
100 COMMERCIAL CRYSTAL 10 LB LBS 1.5 MIL Plastic Ice Bag Bags With Drawstring
$20.50
100 COMMERCIAL CRYSTAL 10 LB LBS 1.5 MIL Plastic Ice Bag Bags With Drawstring pictureBorescope Camera with Light, 16.5ft Endoscope Inspection,Waterproof Snake Camera
$29.99
Borescope Camera with Light, 16.5ft Endoscope Inspection,Waterproof Snake Camera pictureScintillator Crystal CsI(Tl) 10x10x10 mm for DIY gamma spectroscopy with SiPM
$49.00
Scintillator Crystal CsI(Tl) 10x10x10 mm for DIY gamma spectroscopy with SiPM pictureDental ZIRC CRYSTAL HD Neon Mouth Mirrors with Soft Grip Handle - MADE IN USA
$145.00
Dental ZIRC CRYSTAL HD Neon Mouth Mirrors with Soft Grip Handle - MADE IN USA picture
