fast switch
fast switch
Postby firefli » Tue Jun 18, 2013 6:36 pm
I am looking for a way to turn on and off a electromagnet coil mounted on a spinning rotor, as fast as possible.
There can be NO direct mechanical connection. That leaves three trigger sources that I can think of
magnetic, light or sound. Light being the fastest I would think it would be my best choice, but I'm not really sure of that.
Can anyone help me with this? Ideas of any kind would be much appreciated. And maybe some help designing a circuit or where I mite find one.
Thanx
firefli
Re: fast switch
Postby PradeepKumar » Fri Sep 16, 2016 7:45 am
One example of a small electromagnet interacting with a permanent magnet is a loudspeaker. That should give you an idea of how quickly the force on a small coil can change and what sort of power you need to drive it, and possibly you can hack a cheap speaker to create a prototype.
PradeepKumar
$16.79
$106.42
$170.00
SAMSUNG SPW2plus PROM/OTP/MTP PROGRAMMER C & H Technology* MISSING PARTS* pictureT76 Programmer+21 Adapters Support Eprom ISP BGA Socket Tester Clip Socket XGecu
$322.49
T76 Programmer+21 Adapters Support Eprom ISP BGA Socket Tester Clip Socket XGecu picture
