Car anti theft wireless alarm
Postby filtech » Mon Sep 23, 2013 7:06 pm
Hi everyone, I'm new to this forum.
I design a few circuits of my own, just love to work with electronics.
I would like to know if someone has constructed the [b]Car anti theft wireless alarm[/b] as in the circuits category?
I want to construct one for my car but the receiver section doesn't quite make sense, according to my knowledge the cxa1019s requires more circuitry to actually receive FM signals or is it that in this particular circuit it will receive the signals from the transmitter as in the diagram without the extra circuitry?
Your help will be appreciated.
Thank you.
filtech
Re: Car anti theft wireless alarm
Postby pebe » Mon Sep 30, 2013 1:15 pm
I think you are right. There are an awful lot of components that have to be added – it was rather pointless to show it so simply in a block diagram. There is a module made by Philips that is available from several sources, but it needs to be programmed via a (I²C ?) bus, so is of no use to you.
A better choice for you might be to use a 433MHz transmitter/receiver pair like this one from ebay. It uses a super-regen receiver but you will still get a hissing noise from it in the absence of a signal.
http://www.ebay.co.uk/itm/433mhz-Transm ... 3a82b211f0
This one is from China, but if you want to obtain one locally (I don’t know where you live) then Google for ‘433mhz transmitter receiver pair’.
The ‘pic arduino pi ASK OOK’ refers to it being usable with PIC or Arduino micros, and the OOK refers to On/Off Keying (so you can just switch it on).
If you decide that you want to go ahead with that pair and you need further help, just shout.
SK Hynix 32GB KIT (4x8GB) 1Rx8 PC4-2666V HMA81GR7AFR8N Server Ram Memory
$174.99
SK Hynix 32GB KIT (4x8GB) 1Rx8 PC4-2666V HMA81GR7AFR8N Server Ram Memory pictureMultifunctional Cheating Smart Calculator 4GB Memory With Video Photo Text Ebook
$105.00
Multifunctional Cheating Smart Calculator 4GB Memory With Video Photo Text Ebook pictureVWR 620-1965 Traceable 6404 Temperature and Humidity Data Logger W/ Memory Card
$59.40
VWR 620-1965 Traceable 6404 Temperature and Humidity Data Logger W/ Memory Card picture8055SCP452 SYMAX NEW 8055-SCP-452 CPU w/ Ethernet Port
$950.00
8055SCP452 SYMAX NEW 8055-SCP-452 CPU w/ Ethernet Port picture
