load line analysis pls help
Postby als_757 » Sun Oct 06, 2013 10:47 am
[/attachment]Hi All,
Currently we had a quiz for load line analysis,
the question was:
Determine the value of R for the circuit below that will result in the diode current of 10mA if E=7V. use approximate analysis method and graph.
I answered Idq=10mA, Id=11.25mA, and R=622ohms because of the statement in the problem as "result in the diode current" i assumed that idq is the current given.
then my instructor says that the answer (Idq)should be should be 9.1mA.
I am very confused because prior examination i found the same question at Electronic devices and circuit theory but in the book the term "use approximation method" was not mentioned.
I attached the capture of the question.
Am i right with my answer? what is the difference with approximation method?
pls help I dont know if I will defend my answer to my instructor.
als_757
$1500.00
$435.00
NI National Instruments 778643-01 Front Rackmount Kit for PXI - 8 Slot Mainframe pictureNational Instruments PXI-1000B Backplane PCB8 Slot COMTEL 0038862407002850
National Instruments PXI-1000B Backplane PCB8 Slot COMTEL 0038862407002850 picture
