LDR circuit with three level indication
Postby tim1985 » Wed Oct 09, 2013 5:23 am
I need to make a basic circuit that is controlled by an LDR
it will affect two LED's
Low light = 1 LED flashing
Med light = 1 LED on
Full light = 2 LED's on
From what i understand the LDR has to be connected to two transistors to give us 3 settings, is this correct ? or can someone please draw me a circuit diagram explaining?
tim1985
$35.70
$650.00
Carrier 342796-75105 - Evaporator coil OEM Replacement Part *NEW IN BOX* picture8PCS FD508 Ignition Coil Pack & Spark Plugs Compatible with Ford/Lincoln
$54.80
8PCS FD508 Ignition Coil Pack & Spark Plugs Compatible with Ford/Lincoln pictureFirst Co 4HBC 400 CFM Fan Coil 2-Pipe 3 Row Chilled Water PSC Motor LH Brand New
$449.99
First Co 4HBC 400 CFM Fan Coil 2-Pipe 3 Row Chilled Water PSC Motor LH Brand New picture
