How to identify parts from schematics
Postby rameshrai » Sun Aug 18, 2013 6:04 pm
Hello,
I have a schematics but I don't know how to identify realistic parts from the schematics. Like the attached image shows inductors and capacitors with values but there are so many choices of inductors and capacitors? How do we know which exact part is meant in the schematics? Futhermore, there are reactance associated with different inductors and capacitors, must they also be taken into account?
Is there any steps?
Hoping for replies from electronic part gurus.
thanks
rameshrai
Re: How to identify parts from schematics
Postby pebe » Mon Aug 26, 2013 3:47 pm
It is beyond the scope of this forum to give adequate answers to your question - they would require a lot more space than is available. To a large extent the type of component is determined by its value. For example the 10µF 16V capacitor C8 is shown as a polarized type so must be an aluminum or tantalum electrolytic one. C5 is 33pf so quite small and will be a silvered mica or one of the various 'poly' types. If you understand the purpose of each of the components then you can sort out which of their other parameters are relevant.
If you are a beginner then I suggest this would be an excellent reading source.
http://www.allaboutcircuits.com/
Postby sjzrifdsa1 » Tue Aug 27, 2013 3:14 pm
I also encountered the same problem. What should I do?
sjzrifdsa1
Postby pebe » Wed Aug 28, 2013 6:36 am
If you are a beginner then I suggest this.
Postby sachinelectrostar » Wed Oct 09, 2013 9:29 am
I am also facing this kinds of problem...
sachinelectrostar
Postby pebe » Wed Oct 09, 2013 9:38 am
Then my advice to you is the same as I gave to the others!
Hewlett Packard Model HP460BR Fast Pulse Amplifier with Input / Output Adapters
$234.95
Hewlett Packard Model HP460BR Fast Pulse Amplifier with Input / Output Adapters pictureSKAR AUDIO USED SK-M4004D 400 WATT 4-CHANNEL CLASS D MINI CAR AMPLIFIER
$137.49
SKAR AUDIO USED SK-M4004D 400 WATT 4-CHANNEL CLASS D MINI CAR AMPLIFIER pictureUSED SKAR AUDIO SK-M5001D 500W RMS ULTRA COMPACT CLASS D MONOBLOCK CAR AMPLIFIER
$104.99
USED SKAR AUDIO SK-M5001D 500W RMS ULTRA COMPACT CLASS D MONOBLOCK CAR AMPLIFIER picture# BRAND NEW - PASCO Scientific PI-8127 Digital Function Generator / Amplifier
$649.00
