Need to pulse 9vdc?
Need to pulse 9vdc?
Postby takagari » Mon Oct 28, 2013 1:48 am
Hi, glad to be on the forums finally, long time reader :)
I'm new to the design thing. and we are building a bunch of bomb prop's for a play.
I'm trying to find the cheapest and simplest way to make a 9vdc source pulses, once a second.
Will be activating a red LED and a pizeo. I could also use a hand finding the best piezo that give's a nice beep.
9vdc is needed as other item's will also be using 9vdc in the prop. and I need to build 10 of them.
Thank You!
takagari
Re: Need to pulse 9vdc?
Postby pebe » Mon Oct 28, 2013 1:22 pm
Welcome to the forum. I think the easiest and cheapest pulse generator would be to make one from a 555 timer. For a piezo, how about this one
http://www.ebay.co.uk/itm/Medium-High-P ... 53eb8e4c13
or there are many more here.
http://www.ebay.co.uk/sch/i.html?_trksi ... &_from=R40
$75.00
$39.95
Solenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000 pictureSolenoid Replacement for Dentsply SPS Cavitron Gen 131, 132, 136, and 137 models
$175.00
Solenoid Replacement for Dentsply SPS Cavitron Gen 131, 132, 136, and 137 models pictureParker GP600 G-23 77310 Brass Solenoid Valve 120V 9W Sukup Grain Dryer USA
$174.99
Parker GP600 G-23 77310 Brass Solenoid Valve 120V 9W Sukup Grain Dryer USA picture
