Toy activation sensor missing - pinched
Postby OuBallie » Wed Nov 27, 2013 3:50 pm
Hello everyone, I've just joined as I will be adding Android DROs to my three metalworking machines, so may need help at a later date..
First, however, I need some advise please.
Other half bought one of Morrison's (UK supermarket) Halloween Petrifying Prisoner toys at half price just after Halloween.
Unfortunately someone had removed/half inched the small front facing activation sensor, with just two bare wires left where it should be.
Does anyone have any idea what that sensor is and can I get something similar.
The 'toy' works via the 'Test Me' button, or if I short the bare wires.
I will be in credit if I can get it to work via a sensor.
Power is by means of three AA batteries, but haven't checked if connected in //le or series.
I have tried three photodiodes:
Two with dark 'lenses', one being IR Filtered but they only work when a bright light is aimed at them, and the third one has a clear lens that works when light is interrupted.
It appears to need a proximity/movement sensor of some sort.
Ready to file this in the Lost Cause folder and just let her indoors operate it manually, BUT I will be in SHMBO good books if I can get it to work properly
Geoff - A week wasted doing very little.
Petrifying Prisoner
Petrifying Prisoner
Chocolate block to test photodiodes
OuBallie
Re: Toy activation sensor missing - pinched
Postby OuBallie » Thu Nov 28, 2013 10:58 am
Sorry about those large photos.
Must check size before posting in future.
Geoff - 'Can do better'
OuBallie
$35.70
$650.00
Carrier 342796-75105 - Evaporator coil OEM Replacement Part *NEW IN BOX* pictureFactory Authorized Parts -Carrier 342813-75101 Replacement Coil Kit
$699.95
Factory Authorized Parts -Carrier 342813-75101 Replacement Coil Kit  picture1 Pole Air Conditioner Contactor 40 Amp 24VAC Coil Condenser Contactor...
$20.82
1 Pole Air Conditioner Contactor 40 Amp 24VAC Coil Condenser Contactor... picture
