Effects of Wire Length
Postby Happy_Jock » Mon Dec 16, 2013 10:21 pm
Hello Folks
I have quite a few circuits I would like to activate from a distance say, in a room at the other end of the house for example.
One thing that i have no idea of is how the length of wires effect the working of a circuit. by this I mean for example..
If I have a circuit in the front of the house and want to run 2 long wires from the power supply and put a switch on the end, would a long switch wire effect its capability in the circuit.
or a better way of putting it do circuits loose power over long lengths of wire and does the diameter of the wire make a difference, by long im talking around 15-20 meters
any help would be much appreciated cheers
Happy_Jock
Re: Effects of Wire Length
Postby pebe » Sat Dec 21, 2013 7:15 am
Hi H_J,
Any wire has a resistance, and the resistance is higher if the wire is long or of small diameter. Whether it affects the circuit depends on what current the circuit takes.
You can consider your power supply as a voltage source feeding the wire and your circuit in series. So the voltage available from your power supply will be split between the wire and your circuit according to the resistance of each.
For instance, if your wire resistance is 10ohms and the resistance of your circuit is 20 ohms and the voltage is 6V, then 2V will be lost in the wire and there will only be 4V available at your circuit. On the other hand, if your circuit is 100K then the voltage 'lost' in the wire will be negligible. If you are referring to the door sensor in the 555 timer in your other thread, then the length of wire won't affect it.
$1.80
10pcs  1N4007 Rectifier Diode 1A 1000V - US Seller  pictureCHENXL 60A 3-Phase 5-Pin MOSFET Voltage Regulator Rectifier | OEM#
$80.99
CHENXL 60A 3-Phase 5-Pin MOSFET Voltage Regulator Rectifier | OEM# pictureAVR Automatic Voltage Regulator For 3Kw-8Kw Generator Rectifier Half Moon Style
$18.99
AVR Automatic Voltage Regulator For 3Kw-8Kw Generator Rectifier Half Moon Style pictureRectifier Diode 10A 1000V Electronic Silicon Diodes 200pcs for 10A10
$32.62
Rectifier Diode 10A 1000V Electronic Silicon Diodes 200pcs for 10A10 picture
