How to wire up shuttle circuit
Postby nippy » Fri Dec 27, 2013 4:33 am
Hi! A couple of years ago I purchased a shuttle circuit for a model train set. :D
Unfortunately, I wasn't ready to install it and now I cannot find the instructions on how to wire it up. :oops:
Just wondering if someone would like to look at my photos of the circuit and possibly work out how to wire it up.
It is a circuit that has 3 sensors, the train runs from one end to the other of an open-ended track.
The train will stop, wait for a period of time, then reverse back to the original starting place, wait a while then repeat.
Cheers
nippy
nippy
Re: How to wire up shuttle circuit
Postby pebe » Fri Dec 27, 2013 5:33 pm
Hi, Can you post pics of the circuit?
Postby nippy » Sat Dec 28, 2013 5:42 am
Thanks for your reply.
I'll put one of each side to see if you can assist.
I can post more if you need them.
nippy.
nippy
Postby pebe » Tue Dec 31, 2013 2:37 pm
Hi nippy,
Thanks for the photos. I can see a CA4130 and what I think may be a PIC chip. It will help to sort out the circuit if you could overwrite the photos to show all the types of transistors and ICs.
$14.98
6Pack K Type Mini-Connector Thermocouple Temperature Probe Sensor Cable pictureThermocouple Thermometer Temperature Data Logger 4-Channel K/J/T Type Thermomete
$109.71
$50.00
351302170065 Thermocouple Heavy Duty - 72 Inch -  pictureCooking Performance Group Thermocouple 351302170058
$45.50
Cooking Performance Group Thermocouple 351302170058 picture
