Mesh analysis
Mesh analysis
Postby ramy999 » Mon Feb 03, 2014 7:16 pm
Hey, I just need to know how do we write the equations for this problem (link below), i do not need final results. Your help will be highly appreciated :)
[url=http://s1208.photobucket.com/user/ramy33/media/359cab71-86f7-4c60-99d0-3ce5a5dab592.jpg.html][img]http://i1208.photobucket.com/albums/cc365/ramy33/359cab71-86f7-4c60-99d0-3ce5a5dab592.jpg[/img][/url]
ramy999
Re: Mesh analysis
Postby pebe » Mon Feb 03, 2014 7:30 pm
Re the crossed wires at the centre of your circuit. They are shown slightly staggered. Are they supposed to be connected, or do they just cross? And what is 'P'?
Re: Mesh analysis
Postby ramy999 » Mon Feb 03, 2014 7:32 pm
They are connected. Thanks for your time :)
ramy999
Re: Mesh analysis
Postby pebe » Mon Feb 03, 2014 7:42 pm
What is 'P'?
Re: Mesh analysis
Postby ramy999 » Mon Feb 03, 2014 7:55 pm
there is no P. maybe you are having troubles with my handwriting :/
ramy999
Re: Mesh analysis
Postby pebe » Mon Feb 03, 2014 7:58 pm
I was referring to the symbol in the bottom LH corner.
Re: Mesh analysis
Postby ramy999 » Mon Feb 03, 2014 8:43 pm
it's "By loop" since it is a supermesh
ramy999
Re: Mesh analysis
Postby pebe » Tue Feb 04, 2014 8:18 am
Does this answer your question?
http://en.wikipedia.org/wiki/Mesh_analysis
$35.70
$650.00
Carrier 342796-75105 - Evaporator coil OEM Replacement Part *NEW IN BOX* pictureFirst Co 4HBC 400 CFM Fan Coil 2-Pipe 3 Row Chilled Water PSC Motor LH Brand New
$449.99
First Co 4HBC 400 CFM Fan Coil 2-Pipe 3 Row Chilled Water PSC Motor LH Brand New picture5/10/15PCS GTX COIL CORE REPLACEMENT CORE 0.15/0.2/0.3/0.4/0.6/0.8/1.2OHM COIL
$44.94
5/10/15PCS GTX COIL CORE REPLACEMENT CORE 0.15/0.2/0.3/0.4/0.6/0.8/1.2OHM COIL picture
